Difference Between Oil Pumps
Discussion in 'Engine Building' started by tnsxsear, Feb 22, 2003.
  1. tnsxsear
    tnsxsear Senior Member
    Is their any way i can find out the difference between a GSR and a LS oil pump, cuz i got the two I have mixed up and I dont know which is which.
  2. pissedoffsol
    are their any markings on them?
  3. tnsxsear
    hmm,they both have a 3 and an arrow pointing down.
  4. cws13
    cws13 Senior Member
    Athens,GA
    Look at the size of the rotors. The GSR should be moving higher pressure. Or if you are going to build silly Hp toss both sets and drop in a Pro-Drive set into the housing of your choice.
  5. pissedoffsol
