Differences between B16s
Discussion in 'HYBRID -> ED-EF / DA' started by Ryma, Nov 22, 2008.
  1. Ryma
    Ryma Member
    OK so I have been looking at the reference materials and a wiki and it seems the only difference is in RPM and a tune and obd.
    Now the way I see it the b16a obd-0 it makes 160 @ 7600 and 111 @ 7000 but the b16b obd-2 makes 185 @ 8200 and 118 @ 7500.
    Now these two are a good bit apart from each other in terms of power, But could it be that the b16b makes 25 hp and 9 tq over the b16a cause of the obd and higher rpms?
    Could a dyno tune, bolt ons and (B16B)cams on a b16a net the b16b numbers?
    Also another question I was unable to find is is there a difference between the "A" and "B" blocks for the b16 and the b18 as well.
    Thanks and good day
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    B16B= Civic Type R engine. I believe the head is the same as the B18C5/C-R so it has some porting already, in addition to "hotter" cams and higher compression. OBD has nothing to do with it; there's a OBD2 B16A also. The B16B does indeed rev higher than the regular B16As though.
    All the B16B's are Civic Type R engines, while the B16A variants were found in normal sport models(like SiR's).
    Yes, it's possible for a B16A to put down B16B numbers; but you'll also need the head(the B16B head has a little work from the factory as stated before) and probably the intake manifold along with tuning.
    For B16s, the B belongs to the Civic Type R engines, while the other B16s found in "regular" models are designated B16A, B16A2, etc. etc. As for the B18s, the B18A was found in 90-93 Integras, while the B18B are in the 94-00 Integras.
  3. Ryma
    Ryma Member
    Thanks for the info its much appreciated.
    So the only difference between "A" and "B" is vehicle designation? Thats intresting.
  4. K2e2vin
    Raleigh, NC
    Not really; it's just the B16B's are found in only the Civic Type-R. They ahve difference cams, pistons, valvetrain, etc. than teh B16A's
    As far as the B18s, IIRC there's a slight difference in power also but may be due to compression difference and tuning.
  5. Ryma
    Ryma Member
    Pritty much what I was guessing, Thanks a bundle!
  6. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    I thought I read somewhere that 16b's have different deck height/rod length:huh:, could be mistaken though.
  7. Ryma
    Ryma Member
    According to tthis sites referance materials the bore and stroke are the same but the slight differences it says is the C/R differs slightly.
  8. K2e2vin
    Raleigh, NC
    That is correct.
    The B16B's use the same blocks as the B18s. The B16A's have shorter blocks and shorter rods.
  9. Ryma
    Ryma Member
    So the A block would have a better r/s ratio compated to the B?
  10. D16SiHatch
    D16SiHatch New Member
    i dont believe so no. the b16b is basically a de-stroked usdm type r. everything about it is better than a standard b16a. thats why it performs so much better and it carries a much heftier price tag
