* Different Specifications - TODA SPEC B CAMSHAFTS
JDM-Ownz
Someone knows because in the page of TODA RACING (TODA Racing USA - HONDA B16A/18C High Power VTEC Camshaft), says:
Camshafts TODA Spec B:
Spec B IN 250(11.0mm) 250(11.0mm) 295(12.0mm)
Spec B EX 250(11.0mm) 250(11.0mm) 285(12.0mm
And in many forums (included this one) this information about the same cams:
In: 12.0 mm 255 @ 1mm
Ex: 12.5 mm 255 @ 1mm
or
INTAKE lift - 12 mm, duration 255 @1mm
EXHAUST lift - 12mm, duration 245 @1mm
http://www.hondatech.com.au/fo...t=537
https://hondaswap.com/reference...28669/
http://www.ek9.org/forum/resou....html
Which are the real measures? :crook: . That went out new versions of the Spec To (A2) and the Spec C (C2), but of the Series B there are no variants.
Thank you.
