Different sway bars for EG hatch
you could make your own.. just make a template from some cardboard first
Nice! Thanks. I am going to see about some aluminum and talk to a guy that has a axis machine to cut that template. If he can do aluminum and if I want to spend how much the piece is.....
if you get it done LMK how it turns out.. might make one for myself.. my buddies dad works in a machine shop.. he made some custom brackets out of aluminum for my buddies snowboard and bindings because the bolt pattern was different
I think the best way is to have the program he uses
(if its a 3-axis machining tool) But he seems to use
lathes and such.
I need to see a picture of the back. If you look at the side view given...
the recessed lines confuse me. If its just plain flat stock with a 1/2" slug
that's pretty easy to make (like you said) with cardboard. Then the trick
would be to get a cheap piece of T-6061 that is at least a 1/2" thick and
almost 3ft long.
I don't think a 3-Axis machine shop can really touch it and make it a
cheaper alternative to the ASR bar. Make a hundred of them....then
you'll see the potential....but then you got to sell a whole lot of them
I am going to search...again for more pics on the ASR bar. I need a
picture of the back to see if its flat and all that is needed is a slug
I just said hell with it and threw on the GSR sway set up I have.
I cleaned up the LCA's and sway components...then painted them
with black high heat paint. Evey thing went really smooth. I even
took my muffler off, taped off the tip and painted the muffler while
I was back there and it was up in the air. The welds on the muffler
were already rusting (only been a few week)
I'll post the pictures when I get my USB cord back
the brace is not necessary for the GSR bar.
how does your car feel now?
Feels more responsive for sure. I can tell it has more of a sling shot effect when coming around a corner. It just kinda whipped the ass around the corner under acceleration. Its nice.
Getting My OEM strut bar (basic black) tomorrow and looking into a decent rear strut bar. I like the passwordjdm but not sure if its that big a difference over the cheap aluminum ebay ones.
Might get that Beaks kit with the tie bar (wrote a guy selling them and we'll see what he says on $ price $
