I have a weird problem. Wonder if anyone of you have the same problem and manage to solve it.
When I turn my ignition to position III which is when the fuel pump relay activates and the oil and battery lights come on, the chk eng light appears and disappears. Then after which I turned it back to II, very dim lights are left on my gauge cluster, such as the oil, battery and brake indicators. Even after I remove the key from the ignition, the lights are still there. To turn them off, I either need to start and turn the engine off OR I can pull out and put back my ecu fuse.
Anyone know what is causing the problem above?
