Direct Ignition
:) I mean in comparision tosome of the aftermarket jazz you can buy. would there be any reson to need to modify it to get it to burn the mixture better as you tune you vehicle more.
I guess what i am asking is, if it is suffient enough to be used with out modifying it as you add things like a Turbo.
I would like to turbo this car (the wife says i can't until the warranty run out but blah to that)
1. Waiting for the warranty is silly.
2. The stock ignition is more than enough unless you're gonna pull 12k or something. You won't be doing that with a turbo.
