$450 picked up for:
OBD1 B18A1 full longblock(flywheel, 6 puck clutch, and PP still mounted on the motor)
all mounts/brackets upper and lower (including transmission ones) out of a 94-01 Integra *Everything you need to mount it in an EG/DC*
94-01 Integra axles and halfshaft
Stock Exhaust manifold
I'll take some better pictures later, All you would need is your own transmission, ECU and shift linkage and you got yourself durty cheap OBD1 B series swap!
Located in Ottawa, IL 61350
