Yes. You're not changing the shocks, just the brakes. As long as you retain your stock spring seats up top and the stock lower control arms, you can still use your stock springs/shocks.
Originally posted by Calesta@Oct 17 2003, 06:28 PM Yes. You're not changing the shocks, just the brakes. As long as you retain your stock spring seats up top and the stock lower control arms, you can still use your stock springs/shocks.
Gracias, i had read a how to.. and wasnt 100% sure on the springs/shocks... i guess the only thing im changing is the rotors, calipers, e-brake cable, and trailing arms
this is a good article on the set up, I know it is not answering your question, but i just found this and it is a good article: http://tjshondas.20m.com/xlfronts.htm
Originally posted by MaaseyRacer@Oct 18 2003, 12:52 PM this is a good article on the set up, I know it is not answering your question, but i just found this and it is a good article: http://tjshondas.20m.com/xlfronts.htm
