hey everyone.
i have the upper and lower control arms including the hubs and brakes (all disk) from a 91 teg and i wanna put them in my 90 civic hb si. can anyone fill me in on the process and exactly what i would need to change?
it sounds like you have everything except for the brake lines the stock lines wont work. I bought the Goodrich ss brake line kit there longer and make it alot easier.check out this sighthttp://http://hybrid.honda-perf.org/tech/brakeswap.html it helps alot you also need the proportioning valve it will have a 40/40 stamped into it its for the disc brakes.I hope this helps
