dist. problem
Discussion in 'HYBRID -> ED-EF / DA' started by 90civicdx, Nov 24, 2009.
  1. 90civicdx
    90civicdx New Member
    PA
    when in the integra the car ran fine, when i put it in the civic i now get a code 4.
    crank ang. senc. the car runs rough. does anyone know what would cause this and
    what would make my dist. not work now? i did the test on it with the diff a,b,c,d,e pins i got continuity.on the f,g i got no reading.thi9s is the only code i get now , cleared the map code.
  2. EF4Life
    EF4Life New Member
    If your civic is a dx, you have to make the switch from dual point injection to multipoint injection in order to run a b-series motor. part of this swap involves altering your distributor wiring. refer to the write-up in the swap article section.
