Distributor direction???
Discussion in 'General Tech and Maintenance' started by CX Hatch, Jan 15, 2010.
  1. CX Hatch
    CX Hatch New Member
    Which way is the little "key" suppose to face where it meets up with the camshaft in the head? There is a smooth side, and a side with a slit. When I try it, both sides seem to fit the same.
  2. ZCpowerdSI
    ZCpowerdSI New Member
    ON, Canada
    Just try it one way, if it doesn't work then flip it around. won't hurt none. And it's so simple
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    It's should only go in one way. If it goes in two ways, something is wrong.
  4. sleeper88
    sleeper88 My mom thinks i'm cool
    Parkesburg, pa
  5. reikoshea
    Dallas, TX
    im pretty sure the slit on my h22 ran straight through because we put it on backwards when we swapped the dizzy from my h23.
  6. 90si2
    90si2 New Member
    just set the motor so the first cylinders top dead center then set the distributor so that the rotors facing top dead and youll know which way it goes
  7. B16RacerN2NR
    Moving back West...
    Well i'm not an h series or f series guy but I know for sure they only go on one way for the d series and b series.
