I have a 94 integra gsr and I was trying to rig up a 97 gsr unit - the unit looked the same - bolted right on - the wire harness was seperated in two small harness vs the 94 gsr distributor which has one fat harness - so I broke the plastic on the small harness seperated the distributor harness prongs and turned the prongs up and down and it connected right up - it seemed that honda made the harness design different -two prongs pointing left and right instead of up and down - it seemed to work- the top plugged right up - the bottom was mickey moused but IMO it seemed to work- i'm in the middle of fixing my stripped integra - found a 97 at the junks took the ecu obd2 and bought a jumper but I have everything plugged up but the car won't turn on - it could be 2 things at this point - I had cut the harness up from my 94 unit before I had the jumper and tried to color match the obd1 harness up to a obd2 harness -but of course it had way too many wires - so I saughtered (spelling?) it back up - had two red and two blacks which I had to figure out which went to what harness on the obd1- kinda of took a chance and I think I have the reds okay - one was leading to an injector the other to something other sh!t - but the blacks I was wondering does it matter if I had them mixed up -because in my book it should them as if they lead no where - which give me an idea that perhaps there just grounds - holla back if any one has any insite -
