Distributor help.
Discussion in 'Civic and del Sol - EG and EK' started by GlassHeadlights, Nov 29, 2008.
  1. GlassHeadlights
    Calgary, AB
    I just put togther my Mini-Me swap on my 90 Civic Si. It had no spark so I put the OBD0 dizzy and ECU back on and it fired right up. The OBD1 ECU I have works fine and my wiring is correct so it has to be the dizzy.
    I heard the main reson the dizzys fail is the ignition module also known as the igniter fails. The number two failure I heard is the coil.
    What do you think is the problem. I'd like to try to fix this dizzy before I buy a new one.
    Thanks, Brad
  2. D16SiHatch
    D16SiHatch New Member
    I dunno if you have an advance autoparts store near you, but the one near me was able to test the ignitor in my dizzy for me. so maybe they or a similar autoparts store could test yours for you
  3. GlassHeadlights
    Calgary, AB
    I took the coil out of our 90 Accord and it fired right up.
    Thanks anyway.
