distributor problem
Discussion in 'General Tech and Maintenance' started by 93gsintegra, Dec 4, 2004.
  1. 93gsintegra
    93gsintegra Member
    sorry if you heard this one befor but i have a 94 da 1.8l and it was running like it droped a cylinder, so i did all the normal tune up stuff (plugs,cap,rotor) and the car ran the same so while the car was running i pulled off the #1 plug wire, and after a few seconds the car died sounded like someone just turned the key off...well its been a while now and i cant start the car back up?? it has not started scince it died?? i checked all the teeth on the timing belt and it looks new?? and car is in time and belt has good tension... i am thinking i killed the distributor but ?????? will a distributor drop a cylinder befor it goes out?? please help
  2. 93gsintegra
    93gsintegra Member
    sorry it is a 93 integra gs not a 94
  3. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    buy a dissy put it on if the problems still notgone take it back
  4. 93gsintegra
    93gsintegra Member
    bump ( i could really use the help )
  5. hcivic.com
    is that dissy still working for you?
  6. brian11to1
    brian11to1 Senior Member
    Yea check for CEL's. If the distributor is bad you will have eitehr of these codes...
    4 CKP - Crank Angle Sensor
    8 TDC - Top Dead Center
    9 CYP - Cylinder Pos. Sensor
    15 Ignition Output Signal
    If you have any of these codes you may as well replace the Distributor of have it reubilt.
  7. 93gsintegra
    93gsintegra Member
    how do i check the cels??
