did a b18 swap in my ef. bought a round plug for my distributor and i need to re-pin it. need to know where the 5 wires from my dx harness and the wires from c1 and c2 go. pics would help a bunch.
is it a b18A1 swap obdo if it is then match your colors just make sure you dont mix up the 2 white one's.IN your ecu plugs b10/b12 should be empty cut c1(orange) c2(white) n move the orange to b10 n white to b12 now run wires from c1 n c2 into the engine bay n label them c1/c2 Now C1 will go to the blue/green stripe on your dizzy n C2 will go to the wire that is blue/yellow stripe on the dizzy now this is just for your dizzy hook up also on your TPS sensor you need to switch the 2 outside wires (green/white-yellow/white)P.S if you mix up the 2 white wires on your dizzy your timming will be severly retarded and what style of injecters are you going to be using peak and hold or saturated cause peak n hold needs a resistor box let me know if i could help on anything else good luck LSVTEC
