distributor wiring
5genracer
Can anyone tell me what the wire colors are on the distributor side of the plug for a d16z6 engine, and what they go to? I am trying to do an OBD-1 conversion in my brother's CRX, and the wires are cut on the distributor, but they are not the same as the wiring diagram.
:cliffs:
What wire color on the distributor side of the plug matches with what wire color on the harness side for a d16z6 engine?
Thanks.
what diagram are you using?
i have an aftermarket dizzy, so i can't help you on that regard, cu zwho knows if they used different wire colors
I am using a factory wiring diagram, but the distributor plugs were cut off, and the wires are different colors on both sides of where the plugs should be. I just need to know what colors match up on the plug so I can solder them together. Stock distributor also.
