distributor
Discussion in 'HYBRID -> EG-EK / DC' started by 92LScivic, Aug 23, 2003.
  1. 92LScivic
    92LScivic Member
    im swapping a 96ls into a 92 hatchim staying with OBD1 do i need a different distributor
  2. darwins_vtech
    darwins_vtech Senior Member
    Wisconsin
    you need the LS distributor. to make it work. If the LS is obd2 (i think it is) then you just have to chop the plugs for the distributor wires and connect the wires together by hand. I recomend marking the wires to makwe sure that they connect up right or the car won't run./
    darin
