Distributor
Discussion in 'HYBRID -> EG-EK / DC' started by ngq, Dec 21, 2002.
  1. ngq
    ngq Member
    Are the 97 gsr distributor & 97 itr dist. interchangeable?
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    both b18c both obd II,so...why not?
  3. ngq
    ngq Member
    i thought so but i was not sure,i am installing b18c7 into 96 ex coupe,
    i am going to use tranny,alternator,distributor,a/c copressor,throtle body
    & p/s pump off 97 jdm b18c sir-g. all i have is b18c7 australian itr motor
    with flywheel & intake manifold on it only.
  4. ngq
    ngq Member
    forgot to thank u 92b16vx.thanx
  5. xj0hnx
    C.C.TX.
    Did you figure it all out?What was the problem?
  6. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    In the US Spec engines, you can interchage the distributors. I would imagine that this would hold true for any B18C out there.
  7. ngq
    ngq Member
    i have not done any thing yet,busy with x-mas stuff .i am planning to
    mess with high voltage problem then swap the jdm b18c sir with b18c7
    after the holiday.i do not think there is anything missing from swap.
    Everything on sir-g should swap over.
  8. xj0hnx
    C.C.TX.
    You'll be fine.Any surprises just post em.
  9. ngq
    ngq Member
    thanx for the suppot, i will post any problems that will arise.
    marry x-mas to all members, visitor & staff @ hondaswap. :)
