stmotorsports
Over the past few years I've had a dream (obsession?) of owning a diesel Honda, specifically either a UKDM 2.2CTDi Accord (equivalent to USDM TSX) or a 2.2CTDi driveline swapped into a USDM TSX. There are several reasons behind this and alot of thought has gone into it. If I lived in a different country where you can actually drive these on the road, I would already own one. Unfortunately any of the research I've done on the matter so far leads me to believe that is is simply no way to pull it off without spending mad loot (read hundreds of thousands of $$ for crash & EPA testing, etc). Is there anything anyone can come up with that would make it doable?
what about using a tsx floorpan to rebuild an eg civic or dc teg and titling the car as that?
or titling the car as a hotrod?
