dizzy help
racintweek
i bought a 91 obd0 ls dizzy yesterday for my swap
i noticed that some of the inseide pieces had PM6 stamped on them, which is crx Si right?
the dizzy does bolt to my LS head
i was wondering if the insides of the LS dizzy and the REX si dizzy are the same
if so i am going to swap the insides of my rex dizzy into the housing of an OBD1
LS dizzy and return the one i just bought
i havent looked at my rex si dizzy because it is in my storage unit which i dont ever have time to go to
any help is greatly appreciated if this is retarded go ahead and flame
what are you trying to do?
88-91 Si, HF, LS/GS integra distributors are electrically compatible.
If you're trying to make an OBD0 LS distributor from an OBD1 LS distributor, you need to swap the 24 tooth OBD1 CKP reluctor wheel for the 16 tooth OBD1 wheel - the other sensors are compatible.
im trying to make a OBD0 ls dizzy from a OBD1 LS dizzy casing(so it will bolt to the head) and a 91 crx SI OBD0 dizzy electronics(so electronics will be OBD compliant)
since now i know the electronics are the same i can transfer them to the LS casing
and i can return the Dizzy i just bought(and cant afford)
