dizzy,injector questions wiring
i am putting 93 ls in 90 dx hatch what do i have to do to go from obd0 to obd1 motor do i have to change the dizzy and injectors to obd0 or can i just change the plugs and does it matter what obd resistor box you use matter
You will need to convert your DPFI chassis to MPFI first. Then you will need the OBD0-1 conversion harness, OBD1 distributor, 4 wire O2 sensor and OBD1 ecu. The obd1 injectors are optional, but if you decide you want to run them, you will need to close the circuit at the resistor box...solder the 5 wires together. You can keep all the OBD0 electronics(OBD ecu, distributor, 1 wire O2s) if you want to as well.
