dizzy problems
Discussion in 'General Tech and Maintenance' started by sonazty, Mar 20, 2010.
  1. sonazty
    sonazty New Member
    okay i tried an obd2 ls integra distributor......people were tellin me that all i would have to do is cut off one of the ears/legs the one by the vtec solenoid and that this would work. well i got one from a buddy that was good, and it already had the ear cut off of it. went to go put it on and only the top leg meets up. the one that is at the 7 o'clock position isn't lining up. so what's going on here, i was told that ls integra dizzy would fit and it isn't. took the igniter out and put it in my dizzy and it's still throwing a code 9. any suggestions or input is definately welcomed.
  2. invisibledemon
    Tn
    what are you trying to put it on?
    why not just buy the one for your car?
    you should just buy the proper part and fix it correctly.
