Dizzy ?'s
noobvang
Just as title says, I'm having trouble with my swap. Running OBDIIa, but I have a 99-00 si dizzy installed. Wondering if 96-01 gsr are different.
Same? Different? Help? :worthy:
Can this be the problem for my motor? Idles fine but when I go to try and drive it, motor just stalls like mad. I'm just basicly putting along under 2k rpms and really have no throttle response.
I'm about to do a compression test in a few mins. Maybe a vaccume test too if I got the guage. Can't really do timing because idle is too high or irradic(sp?).
OK, compression is 250psi across the cylinders.
Vaccum..... got 0 inches ????
Manifold leak is my suspision. Maybe the dizzy too.
