Do I have an LSD tranny?
jason22ga
jason91si
Hey,I just swapped a B16 a into my 91 Civic Si and I was just wondering how I can tell if I have a LSD tranny.I see a spot where the serial number was but that has been removed or worn off.Is there any other way to tell if it's LSD equipped?Any help would be appreciated.
If it comes stock LSD then it should be stamped on the casing of the transmission somewhere. If it isn't stamped on the casing, then you will have to take the casing off to find out. Hope this helps.
orwhere the axles go in if you can see all the way to the other side with nothing in the middle its lsd
