Do i have these codes right, video inside.
6 Coolant temperature sensor or circuit
10 Intake air temperature sensor or circuit
20 Electronic load detector - possible open or grounded circuit in ECU wiring.
21 VTEC spool solenoid valve circuit (Civic & Del-Sol)
how can i fix #20?
6 i canfix easily with the sensor from the D
10 i think i have the wires backward
20 i'm stumped
21 vtec is not wired
i need to buy a 99si harness because honda decided to change this plug in the other trims
