Do I need a the injector resistor box??
Discussion in 'HYBRID -> ED-EF / DA' started by Som1Dies2Nite, Aug 2, 2005.
  1. Som1Dies2Nite
    Som1Dies2Nite Member
    Engine:D15B2
    Head:Z6
    ECU:p28
    Injectors used are saturated 10 ohm.
    Do I need the resistor box? I dont see one on a 92-95 engine diagram with the P28 ecu. I am using the redpepperracing diagrams and are not that clear.
  2. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    If you are using the 92+ injectors civic, no, if you are using the 88-91 Civic, 86-93 teggy, or any 'lude injectors, yes.
    I don't know the specifics of what ohm level is high or low impedence, etc, but those are the yearly qualifications. You have to match ECU to injector style, basically.
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    Saturated Injectors = NO resister box.
  4. Som1Dies2Nite
    Should I use the peak/hold type injectors since I already have the resistor box and the plus side is that peak/hold are suppose to respond quiker? Let me know.
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    If you have a set of peak and hold, use them! They are better.
    Its pretty much the same difference on a stockish motor, though. Saturated will get the job done just fine.
  6. Som1Dies2Nite
    I will go ahead and keep the satuarated inj. So where would the injector wires run if they dont need the resistor box.
