Do I need these wires
Discussion in 'General Tech and Maintenance' started by street_racer_271, Feb 22, 2007.
  1. street_racer_271
    street_racer_271 adrenaline is my high
    manitoba
    This is from when it was automatic, do i still need them?
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    No, you wont need them. You only need the 3 plugs that go into your ecu.
  3. street_racer_271
    manitoba
    this isn't near the ecu...are any of the wires connected to other things?
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
    yes, you need some of them - some are for the reverse lights - some are so that the car will start (remember automatic cars won't start unless they are in Park or Neutral) - some are needed so that you can remove the key from the ignition - here is some info on how to wire it - there is probably more info (and possibly better) on this on other sites - this is just one that i happened to come across
    Automatic to Manual crx conversion
  5. street_racer_271
    manitoba
    Thanks for the information, I'll probably just tape it up onto the main harness that it comes from, easy fix, and won't have to worry about car not starting
