Do i need to align my car after disc brake conversion?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by hondalife97, Apr 25, 2012.
  1. hondalife97
    hondalife97 New Member
    I am gonna do a disc brake conversion on my ek and it need some alignment right now. I am converting all my brakes to integra brakes .
  2. eg6sir
    anytime you mess w/ suspension, whether it just be raising or lowering your coilovers you always need an alignment afterwards
  3. hondalife97
    alright thanks man appreciate it
  4. TurboMirage
    if you are converting the brakes i dont see a need for alignment. but otherwise, what the nazi said.
  5. klyph
    klyph Dismember VIP
    North Pole, AK
    The brake system rides on the hub and does not affect suspension geometry.
  6. phunky.buddha
    Dallas / Fort Worth, TX
    If you replace the trailing arms (what most people do) then you should definitely align the suspension. If you're just replacing the hubs, then no.
  7. hondalife97
    yeah ima be doing the whole trailing arm included swap
  8. phunky.buddha
    That's what most people do- it's very easy to just swap it out.
  9. klyph
    klyph Dismember VIP
    North Pole, AK
    Ah yes, if suspension components are replaced, it stands to reason an alignment is in order.
  10. hondalife97
    alright thanks everybody
