Have you replaced the gasket before? If not replace the gasket and see if that fixes it, might just be a bad gasket.
Your head may be warped, may be cracked. Since you are going to have to take the head off regardless I would say take it to a shop and have them look at it. If you wanna check it yourself keep reading.
You can quick check for warping by laying a metal straight edge on opposing corners (diagonally) and then again on the opposite corners. The straight edge should obviously lay perfectly flat, if not, warped. Also check the block's level in the same fashion, forming an X from the corners.
Depending on how bad the warping is its possible to have the head milled back true.
If you have cracking they can be welded and then have the head milled again, but most likely it will be cheaper/easier to just get another head and replace yours if it is bad.
