do they fit help!!!
elpayaso201
ok i have a 92 hb and i want to take my drum rear brakes and swap them with disk i have a 90 teg compleat will they fit the civic ??? what do i need to do to install
First off, try typing in complete sentences and using the right punctuation. Secondly, DA Integra trailing arms will not work with the EG chassis, due to different dimensions.
You'll want to look for a set of Civic 92-00 EX/Si or Integra 94+ rear arms and disks and E-brake cables from an Civic EX/Si hatch or a Del-Sol with rear disks. Integra or Civic coupe cables will be too long.
Additionally you'll want to source a 40/40 brake proportioning valve from any of the above cars (basically any Civic/Integra with 4-wheel disk brakes) and a larger brake master cyl. The best cylinder is off a 98-01 Integra RS without ABS.
Try craigslist... A couple junkyard tried to rape me w/ their prices
