doch zc swap question
spades614
i have a dohc zc in my 88 civic hatch block has a hole now so i was told i could use a 89 integra engine is it true that it everything will bolt right up
All you have to do is swap the driverside engine mount bracket on the D16A1 for the Dohc Zc one and you are set. Transmission is a direct fit if you are using the same one off the Zc.
