Does anyone make a standalone launch controller?
Discussion in 'ECU's, Electronics, and Tuning' started by civicious, Sep 6, 2004.
  1. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    I've got a VAFC, so I dont plan on buying a Hondata anytime soon. MSD has the Digital SCI, but all I want is a launch controller...Does anyone make JUST a standalone launch controller?
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Yes, MSD makes one.
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
  4. civicious
    Houston, TX
  5. b16coupe
    b16coupe Senior Member
    anderson, S.C.
    Uberdata has a full throttle launch and shift control feature.
  6. beerbongskickass
    beerbongskickass Senior Member
    Longview WA
    Why do you want launch control? The only thing I think it's good for is sounding cool. If your racing on the street you can't really use it because everywhere you go the road surface will be different. If your at the track on slicks you will more than likely need to drop the clutch from the rev limiter anyways. I say just get yourself a good suspension setup, good clutch, LSD, and good tires, then go out and practice your launches.
  7. civicious
    Houston, TX
    with a rev limiter, on drag radials, you get virtually the exact same launch every time, and can get hella better r/t's
  8. civicious
    Houston, TX
    rev limiter = launch control
  9. pissedoffsol
    r/t's are worthless unless you are in proFWD or some other class that actually USES a pro tree where r/t counts.
  10. civicious
    Houston, TX
    the local strip here has a sport compact night, with $200 payout for 1st and $100 for 2nd.
    r/t's count, y0
  11. pissedoffsol
    msd's suck. all they do is eat igntitors.
  12. civicious
    Houston, TX
  13. h82w8
    h82w8 Senior Member
    orlando,florida
    It looks like thats just a rev limiter.unless you want to run the quarter at your launch rpm I'd keep lookin'. <_<
