Does burning cooland always = bad headgasket
Discussion in 'Civic and CRX - EF' started by caboose, Mar 21, 2009.
  1. caboose
    caboose USDM to the bone
    Hamilton, MI
    Does burning coolant always = bad headgasket
    I have a 1989 CRX HF and it has the signs of burning coolant (Idles rough, steam from exhaust, "sweet" coolant smell, low coolant). I recently replaced the head gasket on it, so I would hope that the hg wouldn't be leaking.
    I know that a cracked head or block would cause something like this. Is there anything else that I should check first (Intake gasket)?
    Thanks,
    Tony
  2. MthaFuknGreen
    Lodi, CA
    you could have a hole from a water jacket into a cylinder..
    did you clean the mating surfaces well and install the gasket correctly?
  3. caboose
    Hamilton, MI
    I thought that I did, but if the gasket is already bad, maybe I did something wrong... hopefully it is not a cracked head.
  4. Ethan
    Ethan Well-Known Member
    It could be a intake manifold gasket but i doubt it. If you wanna change it id say go ahead.
    Its not gonna hurt anything to change it.
    (1) How long ago did you change head gasket?
    (2) How much did you pay for the head gasket and what brand is it?
    (3) Do you run the car into high rpm's and how often?
    (4) What engine do you have?
  5. caboose
    Hamilton, MI
    1. Between 6-9 months, less then 10,000 miles.
    2. I don't remember what brand (was from ebay). It was part of a complete gasket set.
    3. The car redlines at 5k, I almost never rev that high. I usually shift with the shiftlight (2-3k).
    4. d15b6
    I did a compression test not to long ago and I wasn't seeing any inconsistencies across the cylinders. My big reason for maybe trying an intake gasket was because when I was installing the intake after doing the hg I was having some trouble getting it aligned for some reason. I have a feeling that I might have tore the gasket a little bit or something.
  6. Ethan
    There is a spot where the coolant goes through it if its not sealed it could be you problem. Id say change it.
    1 person likes this.
  7. GlassHeadlights
    Calgary, AB
    I had a D15B2 hatch and I blew 3 headgaskets. I bought a real Honda headgasket and I never had a problem with it again.
    On my D16A6 it has a Fel Pro headgasket and I put a D16Z6 head on it and it sealed fine on that second head.(the headgasket has been on two different heads) It's been about 6000 miles.
  8. Ethan
    wurd... you do get what you pay for.
  9. efhondakid
    Akron-Canton, Ohio
    Pull the rad cap and start the car if it blows bubbles its the head gasket.
  10. MthaFuknGreen
    Lodi, CA
    thats not a good test to see if its a blown head gasket.
    are you sure youre burning coolant?
    have you checked the coolant level lately?
  11. efhondakid
    Akron-Canton, Ohio
    Ive diagnosed a couple that way, compession is pushed through the leak in the HG and shows up as bubbles in the rad.
  12. eastbxc
    eastbxc Custom User Title
    Kansas
    Wouldn't there also be bubbles coming up if there was air in the system like a hole in one of the coolant hoses?
  13. efhondakid
    Akron-Canton, Ohio
    But a leaky coolant hose is easy to find.
  14. GlassHeadlights
    Calgary, AB
    I've done the bubbles thing too.
  15. MthaFuknGreen
    Lodi, CA
    thats only if it happens to be blown through one of the water jacket openings.
    just do a compression test.
  16. Ethan
    Just install all oem Honda gaskets... :D lol
  17. caboose
    Hamilton, MI
    Ok, so now I'm sure that it's a head gasket. Walked out to the car yesterday and saw a puddle of antifreeze about 4' in diameter under the car. Looks to be coming from #4 between the head and the block.
    Why is it that things like this happen when you are trying to sell something?
    Pulled the CRX back in the garage where it's going to have to sit for a while. Does anyone know about how much a honda hg runs? I'll probably have the cylinder head checked for warp too while it's out.
  18. eg6sir
    when you replaced the headgasket before was it because it was blown?? or did you do it just to do it... if it was blown, did you have the head resurfaced before you put it back on?? did you torque everything to spec? .. what you've described is a blown headgasket.. if the steam/smoke from the exhaust smells sweet you're burning coolant
  19. caboose
    Hamilton, MI
    I had a suspicion that the head gasket was going out on me, so I replaced it. The one that I took out was not the factory headgasket either. I did not have the head resurfaced. I did torque all of the head bolts. I also put them on and took them off in the correct order.
    At this point I'm sure that the one that is currently in there is bad.
  20. eg6sir
    get an OEM honda gasket and have the head checked to see if its warped at all..
