does changing your spark plug wires to nologies or
Discussion in 'General Tech and Maintenance' started by nocturnal, Oct 11, 2002.
  1. nocturnal
    nocturnal Junior Member
    or some other after market plug wires make a difference? i thought i read a post here saying that using the stock OEM wires were the best? is there any truth to this?
  2. sportlinecrx
    sportlinecrx Banned
    here is something i posted a while back...
    this dyno test supposedly ends the debate on NGK spark plug wires vs. OEM Honda wires
    http://www.vtec.net/articles/view-article?...article_id=8680
    here is some great info on aftermarket wires IMO, even though its by a wire company (magnecor):
    http://www.magnecor.com/magnecor1/main.htm
    bottom line, after hearing from others and researching, i went with Honda oem wires and NGK V-series copper plugs.
    BTW, most of the people here, including mods and admins recommended Honda or NGK wires to me, and Honda wires are not made by NGK, only the plugs are.
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    I've got Magnecors now, they run and fit great. I used MSD, they were shite. Haven't used stock wires for a while now, but they worked great way back when as well.
  4. sportlinecrx
    sportlinecrx Banned
    for me it was a toss up between magnecors and oem honda wires, but i figured since the dyno tests proved oem was better than NGK, then maybe oem is better than magnecor too. guess i will never know, unless i find some dyno results.
    i read an interview with the spoon sports founder (cant remember his name), and he is considered to be the godfather of honda performance. he says the biggest thing he sees being done wrong these days is people swapping out oem honda parts for aftermarket items that aren't any better. he says people dont realize that the parts from honda are already of very high quality and extremely well engineered.
  5. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    IMO, and this is just me.
    Nology wires are junk.
    I use NGK wires, and they fit perfectly, and I have had NO problems with them.
    I think they cost me $85 for the set.
  6. pissedoffsol
    INSERT any moron who bought msd ignition boxes here.
    Honda ignitions are top notch.
  7. Prowler
    Prowler Super Moderator
    B MT
    Take into consideration the article is over 3 years old.
  8. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    That doesn't matter, if you are not running boost or N2O the stock Honda ignition works as well if not better than the aftermarket parts available.
  9. pissedoffsol
    i am gong to run the stock honda ignition even uinder boost.
    its good to 10,000 rpms easy.
  10. bte15
    bte15 Senior Member
    Bellevue, Washington
    nology wires do nothing i have them and there is no difference
  11. sportlinecrx
    sportlinecrx Banned
    actually, its from the august 2002 import tuner. the one with the spoon s2000 on the cover.
    heres an exact quote (for anyone interested):
    Tatsuru Ichisima
    "What i would like to see is a shift in mentality in the way builders are assembling the motors. People need to address the fact that factory components are very high quality."
    :worthy: :worthy: :worthy: :worthy: :worthy:
