dohc f22 into a 94 prelude si
saint_chris
will everything bolt right up like my tranny and my harness? can I use my h23 clutch and tranny and will my h23 ecu work on the f22 dohc motor is it truse if I use my h23 ecu on the f22 will it run more power.. if you can help lmk asap!
The dual-cam F22 is essentially the same thing as an H23. You won't see a power increase from using the H23's ECU, but it should work fine. Oh, and yes, the transmission should bolt right up as well...
