DOHC ZC.. can anyone help??
Discussion in 'Civic and CRX - EF' started by xXHondaBradXx, Jul 6, 2009.
  1. xXHondaBradXx
    xXHondaBradXx 2 FAST 4 YOU!!
    Ontario, Canada
    hey! i just swapped a dohc zc into my 91 civic si.. i went to buy a timing belt for it.. i tried the belt for an 88 prelude because i heard it fits.. it was too small.. then i bought the belt for an 88 integra.. that was to big...then i went and bought the belt for a 90-91 integra.. it fits good but im a little iffy about it...its the first timming belt i have done on a dohc engine.. then when i went to get spark plugs for it, they said that the 90 and 91 integra engines are 1.8L's.. and the 1.6L's are only in the 88 and 89 integras.. so i got the plugs for an 89 integra.. im confused.. i dont know what year my DOHC ZC is.. i want to find out... i bought the engine from some guy that lives near by....he said it was a 91 b16, so he doesnt know shit. do i have the right belt, and plugs??? Thanks..
  2. xXHondaBradXx
    Ontario, Canada
    on the block it just says ZC!
  3. intheearlyhours
    intheearlyhours New Member
    im having the same problem as you. I hate working on this engine. I cant figure out what to fix on my car for the life of me
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
  5. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the correct timing belt for the 88 and up JDM DOHC ZC is the same as the 88 Prelude 2.0 Si - Honda Part No. 14400-PK2-004
  6. jlicrx
    Colorado Springs
    if the serial number of the engine (just below the 'ZC') begins with a '2', the engine is 88-91 OBD0 - if it begins with a '3', it is 92-95 OBD1
    the year of the engine can be found by looking on the side of the head between the #2 and #3 exhaust ports - the number on the head is the year the head was cast and usually means the model year of car the engine was in is one more than that number - head marked 89 came in 90 model year - no number on the head is 88 model year car
  7. xXHondaBradXx
    Ontario, Canada
    Ok. I checked the head, and right between 2 and 3 exhaust port, on the left side of the line where it says 89 in the picture, it just has an 8, and on the right side of the line it has a 7. And the 88 lude belt was way too small, even when the tensioner was loose.
  8. jlicrx
    Colorado Springs
    the timing belt has to be for the 88 Prelude 2.0 Si B20A5 DOHC - sounds like you got a SOHC belt
  9. xXHondaBradXx
    Ontario, Canada
    So the 88 lude comes SOHC too?
  10. Fernpatch
    Fernpatch Member
    Bellingham,WA
  11. xXHondaBradXx
    Ontario, Canada
    the place that i was going was giving me the wrong belt... there was a mistake in their system.. piss me right off!!!
    k. thanks
