dohc zc crx obd1
Discussion in 'Civic and CRX - EF' started by 91crxzc, Jun 11, 2008.
  1. 91crxzc
    91crxzc New Member
    help wiring from 89 dx hatch. it ran a sohc zc obd1 it also has rywire jumper harrens. car was rear ended i took everything and put it in a 91 std crx . only diff is from sohc zc to dohc zc .crx wont start it has spark, fuel pressure, but i dont think the injectors are spraying. motor is from hmotors HELP is the wiring diff from civic to crx? it turns over wont start if you choke it with your hand it will only sputter what gives
  2. 91crxzc
    91crxzc New Member
    help wiring is from 89 dx hatch. it ran a sohc zc obd1 it also has rywire jumper harrens. car was rear ended took every thing and put it in 91 std crx only diff is from sohc zc to dohc zc crx wont start i have spark fuel pressure but i dont think the injectors are spraying motor is from hmotors help is wiring diff from civic to crx? it turns over if you choke with hand it will sputter what gives
  3. 91crxzc
    91crxzc New Member
    v
