just put an obd0 dohc zc into a 91 crx si. I tried to run it off the stock dizzy from the origional d16 si motor, and it barely idles,and you have to pump the accelerator pedal for it to acually rev up. if you give it full throttle, it will just die out. im on a hunt to find an 88-89 integ dizzy and the sensor for the exhaust cam. hopefully this fixes the problem. If anybody has had a similar problem, or might know the answer, pleas let me know. thanks.
