DOHC ZC turbo, ecu mods?
Discussion in 'ECU's, Electronics, and Tuning' started by joe_91zchatch, Jan 29, 2008.
  1. joe_91zchatch
    joe_91zchatch New Member
    I have a DOHC ZC, i am currently researching all the parts im going to need, one of the big ones is, what ECU and what programming is going to be the best at a decent price. I am not looking for something thats super boosted as i'm building as i go, i just need to know what to start with, currently i have a t3/t4 turbo kit with 38mm wastegate, 5-30psi adjustable. 2.5 inch piping inter cooler, with BOV. 2.5 inch downpipe, I plan on running a lower psi (6-10) as the motor is not ready for anything higher yet. I plan to install 450cc injectors also, a fuel pump if needed. i am in the middle of questioning wether or not to go with a zdyne ecu based on the on board boost control options, any info, or available write ups or parts lists would be great! thanks!.
  2. joe_91zchatch
    No, i plan on having it tuned, but i am trying to weigh out my options, as im clueless as to where to take it for tuning or what ECU to use for the DOHC ZC with a turbo- from what i read most of them can be updated, the only thing i've been told locally is hondata, still looking for a good local shop, but thats proving to be difficult.
  3. joe_91zchatch
    excellent, thanks so much, thats exactly what i needed to read, another question before i jump into this, obviously i need a boost controller, but i am reading these have fuel and map sensor controls built into them, am i to believe i dont need to update my ECU if i am using a device such as the Gizzmo IBC G9020? heres a link Gizzmo IBC - Intelligent Boost Controller - G9020
    this is my first turbo project, i am very understanding of honda mechanics, but never ventured into boost. thanks for your help and patience.
  4. joe_91zchatch
    cool, appreciate the 411, sounds like i need to get an ecu and find a local shop - or start learning these tuning applications myself (ha) thanks for your help
  5. Briansol
    chipped/socketed pm6 with turboedit is probably your best bet for the money
  6. joe_91zchatch
    in using a pm6, witch wouldnt be a problem i have a stack of them from building civics, is it not going to be an issue with the sohc vs dohc? i assume the chipping will adjust the fuel mapping?
  7. joe_91zchatch
    thanks for the clarification - no need for the attitude bro - ill take my questions elsewhere, scratch my comment on thanking you for your patience.
  8. BrutalB83
    Rochester Hills, MI
    The point of chipping is that you are able to reprogram a given ECU to run whatever your motor setup is. All you need to worry about really is finding an ECU that can easily be chipped and modified (the PM6 will work fine in your case), and not about what type of motor that ECU originally was paired with.
    For example, the P28 is probably one of the most popular ECUs to use due to it's ease of chip-ability. People use it all the time for the dual-cam VTEC builds, even though it originally came paired with the single-cam D16Z6.
    Hope that helps clarify things a bit...
  9. joe_91zchatch
    thanks brutal, makes perfect sense.
  10. joe_91zchatch
    you win - your cooler than me.
  11. angelo0426
    angelo0426 New Member
    dohc turbo
    learn from me the dohc does not hold boost well i had my boost controller set at 8psi and down shifted the other nght and blew a hole in the side of my block so if you plan on boosting a DOHC ZC DO NOT DO IT WITHOUT A PRO TUNE and do not listen to anything about how easy it is to tune your self its not i am proof i have hole the size of my fist in the side of my block i have to get another motor now! :(
