dohc zc
would the crank pulley off the 89 crx si motor fit onto the dohc zc???? 2nd. Would the clutch and plate fit off the sohc vtec zc???
The pulley may or may not fit, I have seen it both ways. I have an HF pully on my DOHC ZC, you will have to just try it. The clutch from the vtec motors will fit but you have to use the flywheel too.
