Dohc Zc
Discussion in 'ECU's, Electronics, and Tuning' started by crxracing77, Feb 20, 2003.
  1. crxracing77
    crxracing77 Senior Member
    west lafayette in or clw florida
    I have the 89 teg ecu on my zc/crx. i was wondering if im gonna be better off with the crx si ecu? and if i should have any chippign done to it and what ?> I am planing on putting a 75 shot on it.
  2. thuy
    thuy Junior Member
    I assume your Integra ECU is a PG7. I have an 89 Integra PG7 in my CRX with my ZC engine. I wouldn't put back the SI PM6, because the Integra ECU has more aggressive timing and fuel maps. It will simply work better with the ZC engine. If anyhing, I would love to get my hands on PM7 ECU, which is actually made for the ZC engine, but they are expensive and rare. I was also told that if you chip the SI PM6 ECU, that PG7 will still work better. I'm not 100% sure about that.
  3. crxracing77
    ok thanks for the reply i will check into that... i have heard so many stories abt the teg and crx ecus one being better then the other... ?
  4. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    i have heard nothing but horrible things about the zc ecu, kinda like that it tends to make up its own mind about where the rev limit should be, and does it very often. that alone would make me not want that thing!
  5. crxracing77
    your right it does do that but i didnt know this before i bought it so now i have to find a cheap crx si ecu
  6. BlackJDMdeath
    Wichita, KS
    :( sorry, i guess i didnt get you the info in time
