Doin a JDM H22a swap into my 95 Accord LX
st95accord
So i'm finally getting around to this swap and I just need to know if i'm missing anything from my parts list:
engine
tranny
ecu
clutch/flywheel
timing belt
header
high flow cat
prelude driverside motor mount
water pump
timing belt tensioner
blance shaft belt
plugs
wires
cap
rotor
low temp thermostat
MAP Sensor
EVAP Canister
Do I need anything else?
do you already haave the whole h22 complete swap already? if you havent bought anything yet, get the complete swap at say hmotorsonline and start from there. it'll be much easier and cheaper than going part to part.
cuz if you are just going by your list there are tons of small parts you'll be missing, like a bunch of sensors, the waterpipe in the back, etc.
You'll also need a bunch of spare wires for wiring VTEC, IAB and knock, along with needing to lengthen some wires.
Don't forget new oil and a new oil and air filter.
