doing H22A swap on 92 lude...
shortbusrebel07
ok i have the motor out of the car, well its hanging in mid air, im using a chain hoist. my question is does the 92 preludes have an electronic E-brake ? because we are trying to push the car backwards so we can lower the engine off the chain hoist onto the ground. but the prelude wont move, and the E-brake is off.
im hella stumped please help !
oh and if this is in the wrong forum please move it to the correct one. thank you.
I'm 99% sure that your E brake is a cable pull type. I could be wrong. Try pushing it forward slightly to break the brakes loose, then push it backward. If you have had the car parked for a while with the brake on then it might have jammed or rusted together slightly.
Rear drums, or disks?
its cable as far as i know...but if the car has sat in one position for a long time with the ebrake on then chances are it is stuck, so your gonna need some alternative to just pushing it with manpower to get it to move
[post=377156]Quoted post[/post]​
disks. on the rear brakes there is a black wire with a gray stripe that comes off and runs towards the front of the car. thats why i was thinking its electronically controlled. and i cant move it forward the car wont budge.
[post=377159]Quoted post[/post]​
yea we moved it back already by hooking a chain to the tow hook, then the other end to a big f-250 dually, jacked up the rear of the car, then slowly pulled it backwards.
:thumbsup:
Wen I move the front of my car, I jack up underneath the tow hook and roll the car around by hand. I have a big jack on wheels though. I didn't know what you would put the jack under to get the center of the car, so I didn't suggest it.
