ok first off...i have an 89 civic with an Sir2 motor but i was using a pr3 ecu. so i swapped out the distributor for an SiR one...i finally get it hooked up but the same code keeps being thrown and it's making my car run crappy...the code is "9" which is TDC...with the Sir2 distributor my car would tach out at 3200k rpm...now with the SiR distributor i reved it close to 7k rpm...i could of went higher but i think but i didn't try...anyways...i floor it and the car revs up very slow...real slow...so pretty much the only difference i got from changing distributors is that i can rev higher...anyone know what i should do because me and my friend's are out of answers as of right now and none of us have a helms...thanks
