Door Jam
Discussion in 'General Tech and Maintenance' started by knocturnal, Jan 10, 2003.
  1. knocturnal
    knocturnal Junior Member
    In my '91 Accord, the door won't open. The locking mechanism inside the door is broken. The only way i can fix it, is to open the door~which i can't do.
    Does anybody have any advice as to how i would get it open??
    Thanks in advance....
  2. mrblk
    mrblk Member
    bay area, CA
    can you get the inside door handle taken apart, i dont have a accord to look at, but in my crx there is a screw behing the door handle on the inside, i would start with that, because its going to be pretty hard to get the door panel off with the door shut(ie impossible without wreaking it)
    good luck
  3. knocturnal
    yeah, i can take it apart~ but i haven't yet. I'm kinda waitin' til the weekend before i go any farther
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    In alot of cars, when you take apart the door, there is a cable that actually opens the door.
  5. knocturnal
    true, but the main screw i need to take the inside panel apart, is in between the door and the dash
  6. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    hey in civics and accords the door mechanism is operated by a series or rods that push and pull the mechanism the best solution is to go in to the car and pull off the plastic trim that cover the opening behind the handle (one Philips screw) then see if you can unlock the door using the rod for the look(your door is locked shut) the door panel can the be removed by first talking off the speaker panel then around bottom there are screws undo all of them then the window crank next get a flap pry bar and pop all the clips around the door ( the window crank is held on with a horse clip you need a special tool to remove it or a lot of time and a rag) the door panel needs to come out then up to be removed if it seems to be caught up you are caught on a screw so check for it.
    Once you have the panel off you are basically done and can fix the problem
    Some ass hole trashed my locks broke both before he gave up and went through the window
    So I got to do it the same way the other option is to call a locksmith find one that is flat rate and don’t tell him it might be broken and let him go to work when he gets it open pay the 40 and laugh at him.
  7. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    yeah hcivic is right..... you gotta get in from the door skin, sometimes it's a major bitch to take off when you cant open the door but once you can see the rods i'll figit with them for 5 min to see if i can get anything working, then if not normally it's because one rod got knocked off the other, then you have the pleasure of finding how and where.
  8. knocturnal
    i think i'm gettin' what you guys are sayin'. But there is no window crank, i have power windows...
  9. prawjEKt Cx
    upstate NY
    thats good, less crap to deal with
  10. cws13
    cws13 Senior Member
    Athens,GA
    If the door is not able to be opened from inside or out, then being able to get access to the rods will not help you. The plastic linkage connecting the rods to the latch assembly has broken. You can get the panel off with the door closed, it's a bitch but can be done.
  11. hcivic.com
    there are two diffrent tabs one for the lock one for the latch
    the bottom line is you need to get the inner pannel off
    do you have power locks?
    if so then the lock motor froze up and will not unlock the door
  12. VTECcivicVTEC
    VTECcivicVTEC Banned
    crow bar, a chain, and a dualie.
