door panel insert help
Discussion in 'Body / Exterior / Interior / Cosmetics' started by HondaCivicKid, Mar 16, 2004.
  1. HondaCivicKid
    HondaCivicKid Junior Member
    How do you take the insert out of the 1993 honda civic door panel? Im talkin about the cloth piece on the door panel. I want to rewrap it another color so how do you take it off the door panel. I have the panel out already. Thanks.
  2. Hatchbacks Anonymous
    Hatchbacks Anonymous Senior Member
    Anonymous
    Razor blades. If your going to put new stuff on, just tear it up. You ain't going to get any money for OEM door cloth! LOL
  3. HondaCivicKid
    isnt there a way to take the whole plastic insert out that the cloth is glued to?
  4. Hatchbacks Anonymous
    Anonymous
  5. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    ya look at the back you will see plastic spot welds cut them off
  6. HondaCivicKid
    if you break those plastic welds....then how the hell do you re-attach it to the door panel??? :huh: :unsure:
  7. shaddr3
    shaddr3 Junior Member
    Go to home depot, look for some Gorilla Glue, should work out great for ya~!
