Door wont open
Discussion in 'General Tech and Maintenance' started by ghsbaseball91, Aug 2, 2008.
  1. ghsbaseball91
    ghsbaseball91 New Member
    Catawba, Virginia
    ok, my pass door on my 93 sol has been the biggest pain in the ass lately..the outside door handle hasnt worked for a while but jus recently the inner door handle messed up. i took the inner handle off and the cable is still attached to it and i pulled on it but nothin happens. what the hell coulda happened?
  2. nplsdvr
    nplsdvr New Member
    B'ham, AL
    Not to be a smartass, but...
    is it unlocked.
    that's about the extent of my knowledge anyway.
    :D
    (I'm mostly here for the learning and comic relief)
  3. ghsbaseball91
    Catawba, Virginia
    omfg lol yes its unlocked...the handles are like "free" not doin shit
  4. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Something came loose somewhere. Take off the interior panel and look around.
  5. ghsbaseball91
    Catawba, Virginia
    i dont kno if i can take off the panel without opening the door first and i cant open the door so im fucked for now i guess.lol
  6. Justin66
    Hmmm thats a pickle, ive never had this problem, only a door and hatch that wouldnt latch.
  7. ghsbaseball91
    Catawba, Virginia
    yea it blows cuz i jus figured the cable slipped off the handle but took the handle off and it was still there, pulled on it to open the door and take the panel off but nothin happened
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    Door is activated by a little rod that goes downward from the outside handle. There are several metal/plastic connections in the door mechanisms, so its likely that one snapped. Happens all the time.
    As far as getting it open though.. Thats a tough one, lol.
    Personally, I'd get a coat hanger, straighten it out, bend a small hook onto one end, get a flashlight, roll down the window, and pick away from the window channel. Good luck with it.
  9. ghsbaseball91
    Catawba, Virginia
    jeez some ghetto stuff...what should i be pullin up on?
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    ... the door actuator.
    sounds ghetto, but wtf else are you going to do short of cutting a hole in your door panel?
  11. ghsbaseball91
    Catawba, Virginia
    guess so anyways thanks
  12. 92eg_hatch
    92eg_hatch New Member
    dukes of hazard that bitch
  13. Justin66
    Had to do that to my passenger side in my daytona when it wouldnt open after my friend bent my frame rear-ending me. Fun while it lasted, it was a hunk of shit anyway.
    Good luck on your door problem. Call a mechanic, maybe they will know a trade secret or something?
  14. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Check out CB7tuner. This is a common problem with the 90-93 Accords.
