d15 vtec or d16z6 their is a map sensor on top of the throttle body and one on top or next to the fuel filter whats the name of the sensor on top or next too the fuel filter i need the specific name hope some one knows
The map on the throttle body is the one you want to use. There is also a purge cut off solenoid valve mounted on the firewall next to the factory map sensor.. That might be the thing you are trying to identify.. little round cylinder shaped thing with 2 vacuum hoses on it? One runs to the IM and the other to the charcoal canister?
If not an EF, what car are we talking about here? You have any pics?
