Doubt with my S40 I need some references
Discussion in 'Civic and del Sol - EG and EK' started by natalcarlos, Sep 1, 2009.
  1. natalcarlos
    natalcarlos New Member
    Fort Gordon GA
    Hi there guys, I have doubts about my manual tranny S40 on my DX Civic. The reason why is because I had another one (I can't remember it code) that locked on me after running dry when one of the axles seals got broke. I bought the second tranny from a pull-a-part junkyard but they didn't remember from what Civic came off. The tranny claims to be a S40 but I heard there are more than one and I will like to know if it is from a Civic EX or not. It says S40 - 1503609. Any help will be appreciate. Thanks!!!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    im thinking there all labeled s40, we need to know if it says a000 or b000
  3. natalcarlos
    Fort Gordon GA
    Where I can found that code B000 or A000??
  4. AHHVTEC
    Alabama
    its on the trans, i know on older trannys its beside the axle hole inside a little circle spot, but im unsure where at on yours, i do know yours is a 96-00 d series trans tho
  5. natalcarlos
    Fort Gordon GA
    I will check it out on Friday morning with a lift. The tranny has the code in front but it is what i mentioned before. S40 and over 7 digits. Thanks for the info.
  6. natalcarlos
    Fort Gordon GA
    I can't found that code I'll go to Honda and make them check it for me.
  7. serrilion
    serrilion In my own little world! VIP
    Vermont
    bah who cares hehe, as long as its not a 92-95 cx trany.... ya be alright
  8. Briansol
    basically there's 2 cases, depending on the bearing size on the 5th gen civic lineup...
    A000 = small bearing case = CX/DX/HX/VX
    B000 = large bearing case = EX/Si
    look near the tranny fluid fill plug.
    s40 is actually an Ek-series, found on the 96-00 civic ex. 92-95's are s20- prefixed.
  9. 1cameg
    1cameg New Member
    is the s40 lsd bc mine spins both tire all the time (thanks)
  10. xeroxero
    xeroxero New Member
    Fayetteville Ga
    bump interested.
