dowel pins
Discussion in 'Engine Building' started by typesiracing, Mar 25, 2004.
  1. typesiracing
    typesiracing Senior Member
    ny
    i'm in the process of putting a motor together and i forgot to get the dowel pins for the head/block.....if need them i'll wait for them but i would hate to stop and wait if they aren't really necessary.
    oh yeah i have arp studs to line everything up so thats no prob...
    thanks
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    YES 100 percent. It aligns the block w/ the head. you MUST use them
  3. B16
    B16 Super Moderator VIP
    yay area, CA
  4. phunky.buddha
    Dallas / Fort Worth, TX
    :werd:
    If you just use the head studs/bolts to line it up, you could be half a millimeter off (or less) and not know it- then when you start it up and try to rev, it's all over.
  5. BseriesKllR
    BseriesKllR Senior Member
    Oops :eek: maybe i got lucky :blink:
  6. brasilianstreet
    brasilianstreet Senior Member
    sorry to interupt but i dont want to make another forum for this question , well i got a b16 haed and a ls block im getting the golden eagle ls-vtec conversion kit not system and it comes with dowel pins but what are the srp studs or what ever do i need new ones or whhat else do i need to put the block and head together and gasket comes also?
  7. typesiracing
    ny
    lmao...okay i guess its important enough to wait....will f-series or d series work or i'm gonna have to wait till next week <_<
    thanks for the replies
  8. hybrid89
    SoCal
    that kit will get the block and head together and run all of your oil lines. Good kit, have on myself(with the exception of the plastic collars on the oil feed line). If you bought the whole kit then you are good to go.
    matt
  9. hybrid89
    SoCal
    oh yeah...I highly recommend head studs ARP,AEBS(look into AEBS...much larger diameter than ARP)
    matt
  10. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    DOWEL PINS ARE 100% NECESSARY!!! Haha learn from my mistake, one weekend me and my friends were put a type R head on my b16 and we finshed her all off, torqued her to spec and started her up, not too long after she started blowing white smoke (head gasket) and wondering how the hell we could have mesed up (since we have sucessfully torqued heads many times before) we looked up on the counter and what did we see? DOWEL PINS that we left out
  11. typesiracing
    ny
    hehe...sucks.....thanks for the stories i got the dowel pins, torqued the head, and will continue as planned thanks again.
  12. BseriesKllR
    Maybe thats why i blow white smoke......but my compression was good on all cyl. guess i need to do a leakdown.....car has seen rev limiter plenty of times :shrug:
  13. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
